The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
My right joystick is slightly moving up
I've recently bought this used controller, everything else but my right analog stick is fine.It must've been dropped that the stick has to be pulled up if pressed down. While it's stuck down my game is slightly moving up (Example: while the thumbstick is stuck in place, as I'm playing a first-person shooter, the character starts to look up.) Anyone know if I either have to change the thumbstick or there's something inside that's broken?
Score 18
14 Comments
I have the exact same problem, but I don’t know how to fix it
-TheEight
by
i have this problem too on both sticks
by
This will not Void the warranty. Opening the controler WILL. Best thing is get several Q-Tips and alcohol. Soak in AL then push down in the opening of the JS. Do it several times and getting that alcohol in there. Move your JS back and for a lot. Repeat. Keep doing that for about 4-5 Q-Tips . Remembering to move the JS all around right after the AL goes into the JS. Alcohol evaporates quickly, so let air dry for a little bit and that should help. If it doesn't, but it is better, then do it all over again until it fixes it. If it doesn't help at all you will either need a new controller or to open up the control and cleaning and fixing that way. But, opening the control Voids warranties. So if still under warranty, do not open. ASK FOR replacement. Hope this helps.
by
Do you think nail polish remover would work to?
by
Show 9 more comments
Add a comment
Chosen Solution
If your Xbox One Wireless Controller has a malfunctioning thumbstick and you cannot properly navigate around your Xbox One, see the Xbox One Wireless Controller Has Malfunctioning Thumbsticks problem page for possible problems and solutions.
Every controller stick has what's called a "dead zone" and that's the area that the controller’s position is registered as 0 or no movement.
Over time and with use, the stick’s idle position will drift out of the dead zone, an indicator of this is if it seems loose and moves easily, and will seem to move position on its own because the hardware detects the stick is out of the dead zone.
There are all kinds of novel solutions, like supergluing elastic bands to the inside to counter the drift and hitting them straight down with a hammer... I don't recommend it.
Unfortunately, the only real solution is to replace the stick and its board-level hardware, you'll need a soldering iron.
Fortunately, they're quite cheap
Replace one controller joystick compatible with both PS4 and Xbox One game console controllers. Fix issues like drifting or an unresponsive joystick. Image
Product
DualShock 4 and Xbox One Controller Joystick
$9.99
Score 11
13 Comments:
well i just smashed it in with the handle of a screwdriver and that worked
by
Did it really work?
by
to complicated... my head hurts :(
by
I used my hand. Actually works.
by
I purchased from Mouser (https://www.mouser.com/ProductDetail/688...). The coloring is different and there are tiny little plastic nubs on the bottom that prevent the assembly from sitting flush. Clip off the nubs, solder the new one in place and the controller works again. I found that downloading the "Game Controller Tester" from the Microsoft app store was helpful as well to test the dead zone. On mine, the pot which had the problem had score marks for some reason on the resistive track inside that caused the controller to drift up. Not sure what caused it, but now I have 4 more replacements when my other controllers go bad. Smashing with hammers or screwdrivers would not replace the missing resistive inside the pot. Find a friend that knows how to desolder and solder. It's an easy through hole replacement. You also need a T8 security Torx bit, which comes in the ifixit precision 64 bit screwdriver set.
by
Show 8 more comments
Add a comment
Most Helpful Answer
I went to my device and accessories settings and tapped on "configure controller" and swapped sticks then swapped them back to normal and it seemed to work just fine for me. I'm guessing the system needed to refresh it's memory and detect the right controls when reconfiguring the controller and setting it back to normal.
Score 13
11 Comments:
Thanks that worked for me
by
Worked for me as well. Thx man.
by
wow! thnx man! :D
by
Wow bro I’m shooketh
by
Didn’t work for me:(
by
Show 6 more comments
Add a comment
I punched it, now it works just right. I’m dead serious.
Score 3
3 Comments:
Marco I too just middle knuckle jabbed mine and it’s back to normal
by
Worked for me too lol
by
Worked for me as well, I smashed my controller and now it works perfectly
by
Add a comment
This is a common issue with the joysticks on the controllers. Over time and from use there is a little clip in there that wears down and you start to get stick drift. I have it on 2 different ones, only both are in the left stick for me. Always upwards though.
There are some supposed ways to try to fix this posted online, but none of them fixed mine (anything from pressing hard and moving in full circles to alcohol & cotton swabs to remove oils & dirt - none of which solve the underlying problem).
You can try to take the controller apart with a T-8 bit and spudger and see if anything is broken, but it may or may not be something you want ot get into.
Score 1
1 Comment:
My left stick moves up and down
by
Add a comment
you can check to see if this works. im going to try it tonight with my controller.
https://www.youtube.com/watch?v=moEjjFJI...
Add a comment
Here’s a simple solution.
https://youtu.be/_LePBsn3vkA
Add a comment
You can use DS4Windows to connect your Dualshock controller to your PC. From there, you click “Edit” and then “Controller readings”. This will show a dynamic 2D graphic that will help you to evaluate the severity of the stick drift problem. On mine, the right stick drifts when I steer the left stick, or when I push R3 (right hand side stick down at the center). I tried resetting with a toothpick, switching R and L sticks and back, and also opening and cleaning with cotton and alcohol, but nothing fixed the problem. I’m afraid I’ll have to buy me another of these ridiculously expensive Dualshock controllers, but before I do that, I may or may not pay a visit to AliExpress and check if they can send me just a brand new right hand side stick, so to repair it myself.
1 Comment:
You're aware that we're talking about the Xbox One controllers, right?
by
Add a comment
My controller has the right stick jammed in and it doesn't work when you push in but when I try to look around it always gets stuck in place
Add a comment
I know that iFixit’s premise is fixing stuff by yourself, in other words DIY’ing the !&&* out of it BUT unless you want to take the controller apart and check if anything is broken or replace the sticks it’s pointless to fix it by other methods, especially the ones that don’t involve taking the controller apart. If you don’t want to open it then if it’s still under warranty the thing I’d highly suggest is having it serviced. Either this or just fix the insides. The other solutions seem a little to dangerous and temporary to me.
Add a comment
I’ve been beating the $@$* out of my stick as a last resort since nothing I do is working this controller is 3 months old and I babied it so this wouldn’t happen if you find a solution that actually works pls drop it below before I waste $60 on another one
1 Comment:
Howwwww abouuuutttt. The warranty?
by
Add a comment
This works with no soldering. Only 6 screws.
https://youtu.be/CoLJOjEuIVo
Add a comment
This is how you fix stick drift properly
https://youtu.be/kN8662AqiEE
Add a comment
The stick has two rotating switches that contain circular resistant (I think). I detached the malfunctioning switch with a soldering iron and opened it. There was a small piece of metal conductor with a poped out head and 2 hands. I raised the head and the hands a little and cleaned the resistant layer.
After closing and reattaching the switch, It was working fine.
Add a comment
What tools do I use to open the middle screw hole
Add a comment
can someone please help me:( when i play OV it keeps looking up!! ive tried rubbing alcohol, blowing into the stick, punching it, switching the sticks, updating it NOTHING IS WORKINGGGG please someone help:/
1 Comment:
bro same I’m trying to fix my younger brothers controller but nothing nobody’s “advice” isn’t working like broeokdnsndn &&^&
by
Add a comment
Add your answer
Booce Biggings will be eternally grateful.
Past 24 Hours: 27
Past 7 Days: 179
Past 30 Days: 757
All Time: 711,628
